Aeromotive FPR, rebuild or buy new?
horizontalkev
Supporting VIP
1,000
Jun 28, 2010
great bend, Kansas
My Aeromotive FPR is no longer allowing adequate/steady enough fuel pressure to even allow me to start the car.. Should I just completely replace the FPR or would a rebuild kit (new diaphragm) from summitracing be just as good? Thanks
Depends on what is wrong with the FPR. Honestly though, pretty much the only thing that can go wrong with them from normal use is the diaphragm. Aside from breaking something on it that is. You should take it apart and check to see how the diaphragm looks. If it looks torn and nasty, that's most likely the problem.
Also make sure to check for external leaks, both at the FPR and at the rest of the car. The FPR can't hold pressure if the pump can't put out enough fuel because of a leak or other fuel related issue. You can check this with the car off by pressurizing the system at the diagnostic port.
That said, a new diaphragm will probably only be about $5-10. Might as well try that before buying a new one. Besides, if it doesn't fix it, you will have a spare for the new FPR and only be out a small amount of cash.
Hope this helps!
