2G AEM Oil Pressure Gauge with sensor at head location
alice
309
Sep 7, 2006
Canandaigua, New York
Just got done installing an AEM Digital Oil Pressure gauge with the sensor getting it's data from the head port on a stock 2g 7bolt. My question is should I expect the same pressure as you get at the OFH? On my car (not the one in question), I get between 85-100psi when bouncing off off the stutter box and 10psi at idle. On the car with the AEM, I get 7-10psi at idle and a max of 45psi bouncing off the stutter box. Seems a little low to me but I am not sure if I should expect a lower pressure at the head versus the OFH.
The pressure is going to be lower at the head than at the ofh. So it sounds correct.
