AEM Fuel Rail
Fakie
125
May 22, 2004
Marquette, Michigan
anyone have any experience or opinions about the AEM Fuel rail? I was thinking of getting that since I need to upgrade my injectors anyway. I would also buy a FPR at the same time too. I think maybe B&M FPR out of summit?
no experience with the aem on a dsm, but im sure its good....stock rail should be fine though..ide spend the money somewhere else.
agreed, a 1g rail is compatible with the fpr kits out there. it will flow just fine until you start making a lot, of horsepower and if you ever got to that level you would probably be needing more than the aem rail.
I would spend the couple hundred bucks elsewhere.
i woudl saty away form the b&m and go with a nice aeromotive fpr or if you are on a strict budget then an obx (believe it or not) just like previously stated, stock rail is fine unles you are making crazy power. all the guys down here that are making crazy power are running 8 injector setups. :dsm:
lewroe59 said:
I mthink the b&m, only lets you raise pressure, which isnt what you want with a 255. Aeromotive ..................
you sir are correct :)
