Aem Fpg
toomey200
161
3
May 31, 2006
Mountainside, New Jersey
I just installed my AEM FPR that I bought and i need to hook up a gauge for my fuel pressure. If I were going to hook up the gauge and mount it under the hood where should i tap into for the feed?
I would think there should be a port on the FPR that is for a gauge and it just has a plug in it. If there isn't a port for it that's plugged (never heard of a FPR like this), then you could look for some kind of T fitting or splitter to mount the gauge.
No there isnt any where i can mount the gauge on my fpr. Where would i instal the T fitting for the gauge? On the left side of the rail? (BOV side)?
I just got this from AEM's website :
Universal Adjustable Fuel Pressure Regulator FAQs...
AEM's Universal Adjustable Fuel Pressure Regulator is capable of supporting enough fuel flow for engines up to 1000 horsepower. Our patented interchangeable discharge ports enable the regulator's output to match the output of any fuel pump. Our universal fuel pressure regulator is tapped to accept a -6 AN, or 9/16"x18 fittings and includes a 1/8 NPT port for a fuel pressure gauge or pressure sensor pick up.
I don't know if yours is different or what, but the gauge screws into the regulator itself.
EDIT: Whoops, I'm guessing you mean you want a fuel pressure gauge inside the car? I thought you meant a gauge that attatches to the regulator itself. It would be much easier to adjust if the gauge were on the regulator itself.
I really apprecieate all your help but for some reason there is no where at all for the gauge to be mounted to the fpr. I bought it used so it may be an older model. I want the gauge under the hood and since I cant put it directly on my FPR where else can I get the pressure reading from?
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
