Fpg ?
toomey200
161
3
May 31, 2006
Mountainside, New Jersey
what fuel pressure reg should i buy for a tsi awd with a b16g 550cc injectors, 255 fuel pump, fmic,1g bov, and full exhaust with a SAFC?(all stock engine internals)
Areomotive makes a nice one, Buschur has one. Just look in the parts catalog and you will find something.
The pushlock kit from Import Evolution is fairly inexpensive and likely the best one you can buy for the money. Don't forget to pick up a gauge (liquid filled). Mine cost around 200.00 to my door and has been a great tuning device and a worthy investment. You can find it here:
http://www.importevolution.com
Good luck,
Andy
i apprecieate you posting brands but which model from each brand of those mentioned should i buy that will work the best with my set up?
i would try and find one of the fullthrottle/chargeairracing ones.
they bolt on directly in place of the stock fpr and just look like a bigger beefier version. you then mount a guage over on the fuel filter on one of the universal bango bolt adapters
your particular setup has nothing to do with it. As long as you get a fuel pressur regulator that increases pressure linearly with boost (which all of them named do) you're fine. There's not one that's better for more power with a different setup or anything... Just shop around for what you're willing to pay for.
The Full Throttle Speed units have been on backorder forever (at least they were when I last spoke to the guys at Import Evolution). Get the Aeromotive kit for an easy bolt on solution.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
