2G AEM CD7 + AEM EMS v2
licon
Feb 13, 2014
hermosillo, Tennessee
Hello, I just bought an AEM CD7 carbon for me AEM EMS V2 in my 2G. I have doubts for its installation, before directly asking the AEM support I wanted to get here first.
Canbus channels are taken directly from the ECU right? And of the dash wiring according to are green and white. So far I go.
Sólo hay 2 cables para CAN Bus. Si el color del cableado es el mismo que cuando instalé el CD7 de primera generación, conectaría CAN + (blanco) a CAN1H (pin 87 de la ECU) y CAN – (verde) a CAN1L (pin 77).
ElI have done it like that. I am thinking that it is some configuration that I am doing wrong. I found this information right now that I had to enable in Aemtuner. But it does not work
It's not only connect 4 wires (Power, Ground and 2 CAN BUS wires) and send it. You will have to set the scales, parameters and assign channels in both side the ECU and the display softwares, AEMTuner and Dash Design. It would depend what channels/what sensors you use.
I set mine in my 1g is like this.
