AEM Big Brake + Caliper install questions
16Gee
May 22, 2003
calgary,
Hello,
I just picked up an AEM Big Brake Kit (12.5 inch front, 11.5 inch rear) with the 4 piston calipers. I am looking to have this kit installed this weekend and have a few questions that I hope that some of you gurus can help me answer. I was wondering if anything needs to be done to the master cylinder (replace?). Is it recommended that I upgrade to braided steel brake lines? If so, what is a good brand (or does it matter?). Finally, any gotchas/pitfalls that I should be wary of during the install? Thanks.
No you can use the stock master cylinder..I recommend to empty out all the old brake fluid and upgrd to a better synthetic brake fluid..also YES get stainless steel lines...I am surprised that the kit did not come with it..other then that it will be fairly simple//
