advice on next mod
stevetheman8
Oct 4, 2007
Fort Bragg, North Carolina
Hey I have a 1990 Plymouth Laser RS turbo ive only done some mods, 3 inch down pipe, 3 in high flow cat, and 3 inch cat back, aftermakret intake filter and pipe and upgraded clutch kit. so what would you guys reccomend for me next? every thing else in the car is stock
Upgraded fuel pump, injectors (and a way to control them), manual boost controller, turbo and possibly a front mount intercooler. A wide band O2 sensor is helpful for more accurate tuning as well. Do things in stages and follow the suggested upgrade path.
in the upper left corner of the page you can see the word tech under the menu youll see upgrade paths best advice i think you can get. do all the free mods and then youll have a solid platform to build power from and then so on and so on
Port a few things (exhaust manifold, O2 housing) get rid of the restrictive elbow on the throttle body. Then mbc, fuel pump, and injectors
As said by tbonitz301:
Fuel pump rewire and manual boost controller
(15 lbs max).
Relatively easy, cheap with substantial results. When that is no longer enough, as has also been said; bigger injectors, A/F controller, ported O2, etc.
-Dave
#532
