Advice on 95 AWD TSI
Zonnashi
Aug 13, 2010
Norfolk, Virginia
Edit: Due to a situation where I either took it or watched it go to someone else I went ahead and purchased it. Should I have waited, maybe, but this is not my DD, so worst comes to worst, this will just force me to get (more like happily get) a 6 bolt swap in this instead.
So I had asked your advice once before, and listened to wait, and now a different talon has appeared. I understand this one inherently comes with more issues due to the status of the car, but i'm looking for a project car anyways, and it seems that everything else being in good shape for a project candidate over the engine seems ok. Here's the listing... (1900$, 110k miles)
  • bad engine, very nicce looking shell low miles on chasis
    New Parts Intsalled within the last 10,000 miles
  • Earl Shieb Pant Job
  • Fuel Tank
  • Alternator
  • Master Cylinder
  • Slave Cylinder
  • AWD Transfer Case $1500
  • Coil Over Plug Iginition
  • New Kevlar Timing Belt
  • New Alternator
  • New Alternator Belt
  • Valve Cover Gasket
  • Fog Lamps
  • TPS
  • AFM
  • ECU(Refurbished)
  • K&N Cold Air Filter System
  • Motege Wheels and Matched tires Hancook
  • 6puck Clutch and Light wieght flywheel
    New Parts not installed
  • Tokico suspension kit (Complete) $600
  • Strut and Shock mounts (Complete) $400
  • Clutch Kit $200
  • front brake pads
  • 1g drivers side door handle
Whats wrong with the engine? Also, wtf is the 1g door handle have to do with anything?
I would check for any rust, especially shock towers and frame. Then if everything checks out good i would offer 1600$. Those parts are worth quite a bit and if the shell is in good condition, I think it would be worth it the money. Hows the transmission?
I like how everyones throwing a dollar figure at this... No one knows whats wrong with the engine/head...
I jumped the gun and got it before I could talk him down more. I'm content on price personally.
