Resolved Advice on 02 housing removal
Extensions and wobble bits are the best to work with. Wd40 penetrant works best. If you change your mind and want to crack them loose when it's hot, Wear gloves.
It's not as hard as it looks. Just need to be paitent. Pb blaster it very well and let it sit for atleast a good 30 min (how I did mine)
Don't forget aniti seize when you put it back on.
Remember to disconnect the battery as you can short the terminal on the alternator! Ive done this myself and the top bottom and fronts are easy. The back was the problem but it worked well and took 2 hours to do it all. Remember new gaskets aswell and plenty of time.
Knowing you're not planning on taking off the manifold or turbo. But it would make it a bit easier if you loosen the manifold studs and pulled it away from the head a bit. Will give you an extra bit to work in
Make sure you remove the o2 sensor before you spray that thing down with pb or wd, as if they get on the sensor it will damage it
  • Wanted 6 bolt NT water pipe
    • chrisman287
