adding wires to ECU............
4g63telantra
454
Dec 10, 2004
Toronto,
k so im doing the NT to turbo swap into my elantra.
I have the stock NT wiring Harness in the car now and soon ill be adding my eprom turbo ecu.
What i need to know is when adding the new wires to the ecu (knock, Fuel Res box..etc) do i need some type of clip from the wire to the ecu or does click into the end of the harness (3 small boxs)
The injector wiring changes for low impedance injectors is on the power side so there's nothing you need to do at the ECU. The knock sensor wiring you might be better off going to a junk yard and seeing how much you can pull out of a turbo car. I believe the wire is shielded.
While your there cut off a few of he ECU connectors so that you'll have the extra female pins so you can add the MAF reset wire and other stuff if you get a EPROM ECU and decide to retask the BCS and other solenoids to do more useful things.
Steve
