1G Adding power steering
ADC_1G_DSM
Aug 12, 2015
Chicago land, Illinois
I'm buying a 91 eagle talon tsi and the owner did a powering steering delete. I was wondering what parts I would need to add the powering steering to the car. Thanks
You will need to know the extent of the PS delete. Some would call removing just the PS belt a PS delete. If the previous owner went so far as to install a manual rack (1g only), then you may need:
  • PS rack
  • PS rack brackets
  • PS pump and bracket to mount to the motor
  • PS reservoir
  • PS belt
  • PS High pressure line from the pump
  • PS hard line to connect pressure line and rack
  • PS return line to PS pump
  • (optional) cooler/cooling line
If the previous owner just looped the PS lines using a PS rack, then you will need everything but the rack and brackets.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
