Adding air on AFC with bigger injectors?
xdxoxuxgx
395
Sep 25, 2006
Gilbertsville, Pennsylvania
I have a rewired Walbro 255 HP (with AFPR, don't worry :thumb:) and 560's but under wot from like 4k and up I need to add 20% air on my AFC, which results in an A/F ratio of about 10.7:1. I know it's a little rich, but with more fuel being supplied, shouldn't I be taking away air in the AFC? I even hit fuel cut once or twice. I think it might be because the studs on my fuel pump assembly broke so I drilled the wholes out and put self tapping screws through. That might not have sealed enough so maybe that's why I need to add that much fuel, I was thinking about trying this http://www.dsmtuners.com/forums/articles-engine-fuel/256249-replacing-broken-fuel-pump-studs.html . Do you guys think that would solve the problem, or does it sound like something else?
O, and if this helps too, when I'm cruising at a constant speed the A/F ratio fluctuates within like .3 constantly. Example: cruising at a constant 35, the A/F will constantly swing between 14.7 and 15.
  • For sale 2g 2g auto speedo gear
    2g auto. 97-99 speedo gear. From a GST trans. 29 teeth. Price is shipped Message 702-741-6987
  • Wanted 4G63 WTB 2G black top CAS
    Looking for.Shipped to CA 92707.Thanks.
    • AllanL
  • For sale 2g 2G Black Center Console ( all mounting points are intact )
    2G Black Center Console $70 + shipping & paypal fees* all mounting points intact * locking...
  • For sale 2g 2G OEM BOV Hose ( Great Condition )
    2G OEM BOV Hose $28 + shipping & paypal fees* this is the best condition one that I’ve got in...
