running Rich with bigger injectors?
drethib
63
Jan 25, 2009
Fairbanks, Alaska
Well it's running rich as it is right now
. I believe the stock injectors are going bad. With my mods would I run rich if 660cc inj were installed? Would I have to get myself a piggyback system to compinsate for the size?
theres a big yellow SEARCH tab up top, it comes in handy for moments like these... :thumb:
this time ill use it for ya.
http://www.dsmtuners.com/forums/newbie-forum/254595-bigger-injectors.html#post151136295
you've got a few options but its going to cost you the same in the end. I thought it would be cheaper getting an SAFC, a logger, and a wideband to tune. well, here i am realizing how much MORE i could have done tuning my car just by running DSMlink and the cost would have been about the same... imo id just go with DSMlink, don't make the same mistake i did.
:dsm:
Can't beat the driveability of an OEM ECU. Personally I'd jump on the evo forums and pick up some of there stocker 560 injectors. Seen then for under 100 bucks. These match close to perfectly with a 2g MAF. Then fine tune with an AFPR and a WB02. Throw some alcohol injection on for added safety. Good for a little over 400hp this way(with proper turbo IC). If your looking for more go dsmlink.
