ACT NSK Throw-out bearing and OEM are IDENTICAL!
98TsiAWD
DSM Wiseman
2,861
8
May 19, 2002
94 3000GT VR-4, North Dakota
So like many others I bought an OEM throwout through Conicelli and an ACT 2600 kit through Prostreet (with the newer plastic sleeved NSK throw out)
I took both out of the box and they are identical, they BOTH say NSK on them.
So when buying a new ACT clutch kit, dont waste your money and time getting an OEM one.
If I remember correctly, ACT switched over a few months ago.
same here, i read somewhere nsk makes the oem one so that's what i put on, i got mine with my 2100 kit i bought from prostreet like 5 months ago
hey so where did you guys order your clutch from?
if i order from prostreet, i wouldn't need to buy another TOB right?
when i step on the clutch pedal i can hear grindin noise coming from the tranny area, so thats a bad TOB (throw out bearing) ???
so its betta to fix the whole clutch right?
act2100? or 2600?
I'm running a ACT 2600 pressure plate, a SPEC carbon disk (new style) and an SSG flywheel.....
The 2600 is probably a good choice.
I just went with a different disk in order to have more power capacity without going to the 2900 and 3200 ACTs other people run.
Star Performance Engineeered Clutches...
It is a clutch disc which uses carbon fiber and metalic composites as opposed to a organic, ceramic or full metalic...
act2100? or 2600?
i bought mine from Jeromie at nitrous express ...
Our ACT clutch kits come with only ACT recommended parts and part numbers. They are very high quality. 98TSiAWD is correct in saying they are identical throw out bearings to OEM.
doodie said:
My ACT2100 came with a Nachi TOB which was plastic sleeved. Works great.
yeah mine did too, but I haven't put it in yet. SO it works ok for you then?
    • george bromwell
    • pma1123
    • Sdcryan1
