accessories not working unless car is running
plymouthlazer
31
Jun 14, 2012
columbus, Ohio
I was putting a 14b on my car and accidently touched a post on the alt with a wrench. it sparked and i heard a pop from over in the fuse area.
My locks, seatbelts, and windows (possibly other things) dont work unless the car is running now. Also my abs light comes on and i can feel somthing happening through my brake pedal while driving. ideas on what could be wrong?
thats a horrible idea.. go to the junkyard and grab one.. soldering it, its no longer a fuse.. so if something goes wrong.. it wont blow... could work for years like that, or could start an electrical fire...
HEY!!! Don't solder your fuse that's the stupidest thing I have ever heard.
That makes no sense, it was his fault for shorting the hot terminal on the alternator. What does that have to do with a used DSM?
Because you never know if the previous owner felt like soldering the alternator fuse. LOL
Sooner or later you find out. :)
Whenever I've picked up a used car I spend the first few weeks looking for and fixing the questionable work done by others. Heck, I have to do that every time I take any car, including the ones I've owned since day one, to someone else for service.
It's $3 for the 100amp fuse at Autozone. Buy it. Also, next time you work on your car, disconnect your negative terminal on the battery. It will keep stuff like this from happening...
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
