accel or magnacore??
spidy3
192
4
Jan 20, 2005
upstate, New York
Accel 8mm plug wires or Magnacore 8.5? is there any difference? is magnacore worth the extra $25?
*going on a slightly modded 91 tsi.
:talon: Dom
Im not too worried about the money. I just dont wanna go spend $30 more on wires that wont make a difference. So get the MSD's 8.5? best bang for buck? also anyone use NGK iridium plugs? they worth it?
Not sure about iridium plugs, but I know most guys will tell you to stay away from platinum plugs, iridium might be the same. Most guys say to stick with the factory style ngk copper plugs, go to a colder heat range if you have added performance mods & upped the boost. I have the accel wires & they work great, only thing wrong with them is they are slightly longer then the stock ones so you get a small hump where there exit from the cover, but no big deal. I origionally bought them because they were available locally. When I get my next set I'll probably get the megnacores, just because most say they are the best. Only problem is if they fail on you, ur basically screwed as Ive heard they never cover the product under warranty, somehow its always your motors fault for them not working. :rolleyes:
