AC Pulley Question
GalantGreg
297
Jul 14, 2008
Spring, Texas
My ac pulley nudged up against the timing cover. I to I get this seperated?
Install the bolts along the back edge of the timing belt cover. It will pull the cover in. The AC pulley does not and should not be moved. If you shim it, the belt will not line up. Mine is close also, but it's not actually rubbing. I don't worry too much about it.
