2G AC/heater noise
Where does it appear to come from?
If it is around the glove box area, it is likely your blower motor. If you are lucky, it just needs a good cleaning/lube. You will need to remove it to check it out. This will involve removing the glove box. Then, remove 2 mounting screws for the small black-colored box right under the blower assembly. The blower assembly is tightened down with 3 black torx srews (also 8mm socket). Two are easy to remove, the other will take creative thinking.
