AC/Heater fan won't work correctly at highest setting
jeffc
Jul 2, 2004
Winston-Salem, North Carolina
92 NT 1.8
My AC/Heater fan works correctly in all settings except for #4 (high). When I set it there, sometimes it will come on and work for a few moments, then stop. Changing it bakc to position 3 (or any other position) and it will work correctly. Change it back to #4, and it may or may not work correctly again for a few more moments. Doesnt seem to be affected by inside or outside temp, or position of my gas pedal/rpm range.
Is it as simple as the electric motor starting to go bad? It makes no odd noises either...
I haven't looked at the wiring diagram for this, but it could be the blower motor resistor block or the high speed relay (if it uses one).
    • george bromwell
    • pma1123
    • Sdcryan1
