ABS Removal 1G
drunkin_idiot
May 5, 2010
Peoria, Arizona
Ok so I'm in the middle of doing the non ABS conversion, and like a moron, I cut the rear brake lines off of the prop valve. Now am I screwed and have to find new lines to go to the rear, or would I be safe getting 3/16 compression fittings and trying to repair the old ones that I cut? Thanks
You MUST double-flare them. Most flaring tools suck and are cheap as crap and take a crapload of elbow grease to get a half-ass double flare. I use a press with the cheapo tools instead of the half-ass threaded piece that comes with them. A compression fitting WILL NOT hold brake-line pressure, so don't even attempt it.
