ABS and brake light removal...
Sinclair159
179
7
Apr 12, 2005
Taylor, Michigan
hey guys i tried searching for it, and seen that a couple of people finally just got fed up with the abs light and just took it out.. how do u go about taking out the bulb to the light?? mine has been on for a year now and im just looking to get the light to go off... also my brake light is on too and i havnt figured out why that is still on.. thanks guys.. :hellyeah:
you can take out the bulb for abs in ## gauge cluster, however the brake light that comes up might be your brake fluid i would check the fluid level, if it isnt the fluid level check the e-brake hope this helps
What kinda job is it to get the gauge cluster out?? ive just never had it out to know if its a time consuming job or not?
and as for the brake fluid, that was the first thing i checked.. what else would throw i brake light?
