Abs and Cruise control delete Now What Master Cylinder
spadepro22
1,206
14
Mar 13, 2008
Seneca, South Carolina
I've been reading there is a couple different master cylinders for different models. I have a 93 tsi awd that had cruise and abs, but I deleted them. I'm assuming that I opt for the non abs one? Which one do I get and part number? This is the # I have, mb555133
Your stock MC will work just fine. Its already biased towards your AWD big brakes. You wouldnt notice a difference unless you went larger.
the one you have now and the non abs one are the same part numbers. the only difference between an abs brake system and non abs system is the proportioning valve and abs module. they all use the same master cylinder and brake booster.
If you are replacing the cylinder, I would recommend to upgrade to the 3g cylinder, It's bigger and has the reservoir integrated which that will give a better and clean look, If you end up upgrading your brake calipers in the future, you will not be worried about upgrading the cylinder again.
