About Homemade 4-gauge Grounding Wire Kit
95dsmtsi
Jul 14, 2007
victoria,
hi, do you know if I can use a 8-gauge grounding wire instead of 4-gauge grounding wire to make a homemade grounding wires. does it make any problems to the car like fire or something else?
the wires that i have are for amplifier power(from the amplifier to the battery) can I use them to do the grounding wires.
For grounding the battery to the chassis and motor, use a minimum of 6ga wire, others use 8. Your current flows through the negative side, which in terms should be as short as possible and the bigger the wire, the better.
