a few questions about my 97 eclipse GSX
CBT8503
53
May 25, 2004
Meridian, Mississippi
I've had my eclipse for about 6 months now, and havnt been able to invest any money into my car as of yet besides a new timing belt/water pump. I havnt changed the spark plugs, spark plug wires, or put on new breaks. I took my car to be aligned at a local shop because my car is pulling pretty hard to the left, and they told me that a caster was bent, and an alignment would not do me any good, and I would have to get the frame pulled..... does this sound right? I'm still in the learning process and the reason i havnt had the money to put into my car is because i havnt sold my 96 3kgt SL. And if anyone is interested in buying it just send me an e-mail or PM. Another thing I am worried about is the oil pressure guage. It fluctuates up and down, sometimes it's low, then 5 mintues later it will be on the mid-line. Is this normal? I am running with valvoline durablend 5W30 i believe. What could be wrong here? Thanks for the advice in advance.
-Chris-
Was the car in a accident, that would explain the frame damage. You oil pressure gauge will move up and down depending on your RPM.
Yeah, the car was in a little accident, i dont know what it was because the previous owner did it. The front bumper is in simi-bad shape, but has a skirt over it so you would never tell. The idle also seems a little rough, around 500 RPM at rest.
I don't have any advice on the accident except to ask them to show you the damage. I just wanted to tell you the oil gauges in DSM's are crazy; it scared me when I first got my first one, the needle will sit almost at nothing at idle and move normal as the engine revs.
