a/f install, what parts are needed?
THere's an easier diagram then that one, I dont remember where the diagram is, but
power-Tap into a hot wire that turns power when the ignition is keyed (I used the cig lighter power)
Ground-Use an existing bolt into the chassis (I used one by the ECU)
O2 Sensor Signal-Theres a wire with a female spade up to the right of the glove box just dangling up in there. Its kinda hard to get to, but its up in there.
Good Luck
get a vampire clip...the one that you slide two wires into and clamp a piece of metal down. That way if you have to take it out take the clip off and wrap the wire with electrical tape and and its like new. The other guy said tap the cigar lighter for power, That is what I did the second time because when you dont need the gauge it gets really annoying. So it only comes on when you turn the parking or headlights on. while your down at the ecu find a bolt thats screwed into a metal peice thats bolted to the body(radio support) and wrap wire around the inside of the head and bolt it down clamping the exposed wire btwn the bolt and metal piece. All in all its not that hard good luck, keep us posted.
Andrew
Andrew
Like the ones at radioshack?
