A couple of questions
nicknorth11
663
7
Feb 9, 2005
Grand Blanc, Michigan
I've installed a bosch 044 inline fuel pump under my car and am wondering if the power and ground terminals need to be covered with something to avoid contact with water. As it sits, they're completelyl exposed. If I need to cover them, would that liquid electrical tape work?
Also, I had my valve cover fabbed up with (2) 1/2" hose fittings for ventilation purposes. Unfortunately, they were placed so close to my coolant housing that I can't take my fill cap off to fill the car up with fluid. (It's completely empty, as I just did a rebuild). Can I fill the system by disconnecting the top radiator hose and dumping it into the housing via that hose? Is there a better way than this?
Thanks for the help guys
I would recommend using something rather than electrical tape. The moisture will eventually erode the brass terminals on the pump. Either that or get some of the moisture proof connectors. Some of the early model ford diesels and gas engine trucks use the external pump on the frame. It acts as a High pressure pump. The part number is E2000 Airtex. Check out the hardware that comes with that pump on their website.
As for the recovery tank you should be able to fill it as you mentioned. Some opt to relocate as well
Kolby
