420A 99 GS Alternator belt
Thomas Mason
253
34
Apr 29, 2017
Covington, Kentucky
Someone help! My gs pulled the same crap as my rs, belt for alternator flew off in rain, since this belt sits behind serpentine belt, is there a Easy way to replace this without having to undo the timing belt/serpentine belt... can’t remember how I fixed this before, think I ended up finding out my timing belt was breaking so I took it all off anyway. Appreciate the advice ahead
Timing belt does not need to be removed to get to the alternator belt. You will need to remove the A/C belt though.
I changed mine a couple months back. Took a little over 2 hours to do both, even less once you get used to it. Timing belt removal is not required.
