99 clutch problems gst
Ozyeclipse
88
May 26, 2012
Gadsden, Alabama
I have a clutch problem in my gst
When pressed it feels like in half way it gets hard and feels like it engages
But same when I realease it its about 1/4 of the way and releases quick wich makes the car jump or stall what could be the problem. master or slave cylinder
Before I start taking things apart and buying parts I don't need LOL
yes, try adjusting the clutch first if that doesn't fix it, then you will want to start checking things. Start with the easy things.
I was at that point where the clutch needed to be completely depressed before disengaged. Anywas, I can no long put into gear while engine is running. Just grinds when moving shifter into gear I am very intrested in the OP finding out what it was. Master / Slave CYL sound like the culprit. Or a TOB
Well its been adjusted properly towards its extremely hard but still let's go pretty quick now it just feels like when its pressed all the way it won't let go and just revs the engine way up feels like its slipping now but as I decrease the pressure on the master it gets better and softer just still let's go pretty quick I'm gona try installing a new master tomorrow
Nope new master in there and still no change
