98 GSX ECU pin connector question.
dsmluck
Apr 2, 2013
broomfield, Colorado
I just swapped out the ECU in my 1997 GSX with the back cased ECU from a 98 GSX. I am trying to wire in the reflash and wideband into the ECU and just received the correct pin connectors. Problem if I am not sure how to crimp the wires to the connector as it has to fit into the tiny square hole on the ECU harness. How does everyone do this properly?
Thank you.
I always put the wire in the connector strip and crimp it down, ive never seen that strip before but i would do the best to get the wire in there, kinda have to diy i guess. Have you tried any youtube videos the pics are ok but im kinda confused on what you are doing.
Basically I am just trying to wire the reflash connector for ECUFlash and my wideband into the ECU harness in the specific pins. Its a 97 so it doesn't have the reflash connector like the 98/99. I was told these fit into the harness.
  • Wanted 6 bolt NT water pipe
    • chrisman287
