98 gst no start
kendrick
Oct 26, 2014
gainesville, Georgia
I'm having a bad problem right now don't know where to start this is my only transportation
So I finally got my car running drove it for a little while ran fine starter went bad changed it now ran into this problem car started after changing starter it died when I pressed the gas an would not start all it does is turn over fuel pump won't engage an I'm not getting any spark. I don't know where to start with this problem it started once I changed out my starter its not getting any fuel or spark if anybody know what the problem is plz let me know where to start or what to check thanks
check the mfi relay. its not getting power you won't get anything to work right. if that has no power, check the efi fuse. if thats good test to see if power is at the ecu. if it has no ecu, check the engine or ecu fuse. if thats good and has power look into the ecu. another issue is the crank sensor. if that is bad, you'll have no fuel pump or spark. that crank sensor turns the fuel pump on and sends spark signal
kinda fishy like smell? pull the ecu out and take it out of the box and get a picture of it. ecu may be fried
