98 GST build - finished
SeaveeDSM
Supporting VIP
238
37
Dec 22, 2008
Miami, Florida
About 3 years back I had done pretty much all the bolt-on mods possible on my original owner '98 GST. The car ran great for about 2 years and then in January 2010, to make a long story short, a broken seal on a rubber hose on a vaccuum hose caused a boost leak and after some other issues I killed the engine with a broken rod that cracked the block down near the girdle. Car sat covered for a year. Finally got the time and funds arranged to get the car up to the Orlando DSM guru - Jose Clavijo - for a complete rebuild including a new '99block that he had up there waiting for me.
Yes, I had the option of a 6-bolt build but I am not scared of crankwalk on the late model 7-bolts with their 3-piece floating thrust bearings. My old 98 block had 120K+ miles on it and no CW. The 98+ 7-bolts all use 3 piece floating thrust bearings and in many ways the same engine as the EVo III, which are not known for CW either. I don't wan't this thread to turn into a 6-bolt vs 7-bolt debate please - and its already done on my car so if you want to debate that please create another thread.
First a quick note on the guy doing my build - Jose Clavijo. I was referred to him by the folks at JNZ Tuning who I've bought a lot of parts from. I simply did not have enough faith or trust in ANY of the local performance shops here in Miami to do the job of this magnitude and I had neither the time, tools or the advance mechanical know-how to attempt this on my own. Jose has been heavily involved in the DSM world for many years. He does this entirely on the side from his full time work unrelated to DSMs. Don't let that fool you, the guy isa wizard and can do ANYTHING on DSMs. I can't say enough how great the build experience has been with him. Just as JNZ and the many posts in the link below say, the guy really knows his CHIT, is a straight shooter, 1000% honest and totally reliable. See some of the positive commentary dating back to 2003 about him here: Great Guy: Jose Clavijo (aka Red97Talon) [Mechanical, fabrication, DSMLink] Jose's email addy if anyone in Central Florida wants to contact him: awddsm97[at]gmail.com replace [at] with @.
Now on to my build details.
I'm again the original owner and plan to keep the car very long term - maybe someday pass on to my son when he grows up. My objectives were to try and get around 400HP at the wheels and balance performance with drive-ability and longevity. Jose dyno'd it just this morning on a dynojet dyno and its at 411 wheel hp, 350 ft/lbs torque at 5,200 rpm on E85 and boosted at 22.5 PSI. While he is confident I could easily and safely boost it to the high 20s, I am choosing to stay right here as I am FWD and again want to preserve longevity. Will post pics of the dyno slip and dyno testing later today after Jose emails them to me
EDIT Picked up the car this past Saturday. We changed the old Greddy "long route" FMIC to a Punishment Racing short route FMIC and ran the car again on the dyno - no other changes to the tune. We were pleasantly surprised to find that change alone picked up nearly 20 horsepower! The HP was up to 429. Here are the initial and second dyno run:
END EDIT.
I'll be picking it up either this coming weekend or the following and post detailed pics of the engine bay (the ones currently in the gallery are the old build). The only pending items to do now are replacing the existing FAL radiator fans with some stronger SPAL fans (about 40% more CFM) and also replacing the current Greddy "long route" FMIC with a short route Punishment Racing FMIC.
Bolt-on Modifications/ engine bay upgrades: FP HTA68 turbo with turbine housing ceramic coated // EVOIII intake manifold // FP air intake // greddy RS bov // stock 2g tb // PR fmic // FIC 950injectors // walbro 255 fp direct wired // Aeromotive fpr // FP cast and coated racing exhaust manifold // Evo III o2 housing – ceramic coated // Greddy Evo II 3" exhaust w cat delete // electronic boost controller // prothane front-rear motor mounts // fluidyne radiator // two SPAL puller cooling fans – 11" #30102800HO and 12" #30102038
// optima red top battery // AlterStart 150 amp HO alternator // JMF SST spark plug cover // JNZ tuning white powder coated valve cover // RRE Catch can
Engine Management: ecmlink (V3) // AEM UEGO wideband (rear o2 location) // GM MAP sensor // stock MAF retained // autometer boost gauge // E85 and 93 octane gas tunes
Engine Internals: '99 7-bolt short block // 2G head w 3-angle valve job // fp2 cams // GSC beehive valve springs, titanium retainers, chromoly spring seats // supertech valve stem seals // topline 3rd gen revised lifters // ARP L19 studs // Mitsu OEM steel headgasket // Wiseco 1400HD pistons 0.20 over // Eagle H beam rods // new Mitsu OEM crankshaft // ARP main and rod bearings // ACL Aluglide 3 piece thrust bearing // full balance shaft delete // new OEM timing belt, tensioners, pulleys, water and oil pump, oil pan and oil p/u tube // all other hoses, lines, belts OEM new
Drivetrain Modifications:
FWD GS-T // OEM new 5 speed manual with Quaife LSD installed // ACT 2100 clutch // ACT streetlite flywheel // SS full clutch lines // new OEM clutch master and slave cylinders // rebuilt steering rack
Suspension Modifications:
BAER front Big Brakes // slotted OEM size rear brake rotors // eibach pro kit springs // tokico illumina shocks // front strut tower brace // exel 18" rims // Dunlop Direzza Sport Z1 Star Spec 225/40/18 tires //
Cosmetic/other:New OEM leather GST steering wheel and shifter boot // OEM new sunroof glass (from Dodge 97 Avenger – no longer avail at Mitsu dealers // new carpet / new headliner // new drivers side leather seat reupholstery – exact OEM match // OEM black dash with tan interior // '99 OEM white gauge cluster // red LED gauge & dash panel lighting // new aftermarket stock OEM- match headlamps // painted 2 years ago in Mitsu EVO IX Wicked White – originally Northstar white // Pioneer Premier head unit & amp, 4 Pioneer speakers, 2 pioneer tweeters in oem dash speaker location, Kenwood 12" sub
UPDATED ENGINE BAY PICS added later in the thread.
These exterior shots are from about 2 years ago. The car looks still exactly the same as its been under a cover for a year. The pic above at the Sunoco station was on 6/18/11.
Some on the in-process build pics:
The exterior pics are about 2 years old. The car outside looks exactly the same now however, as its been under a car cover until a couple months back when I took it up to Jose to commence the engine build.
I'll have a few new engine bay pics up with all the new things in a few days.
Dyno results uploaded on the first thread of the post now.
Picked up the car yesterday in Orlando. We changed the old Greddy "long route" FMIC to a Punishment Racing short route FMIC and ran the car again on the dyno - no other changes to the tune. We were pleasantly surprised to find that change alone picked up nearly 20 horsepower! The HP was up to 429. Will upload tomorrow this newer dyno graph when Jose emails it to me (we forgot to get it when we left and they are closed til tomorrow...). The car starts to spool a couple hundred RPM quicker too.
Here are a few pics of the engine bay and a couple of the exterior from the Dyno shop and at a gas station yesterday:
I am in aw as to how hard and clean this car pulls. Love every single thing about this car. Thanks for the drive, it was a freaking blast.
Looking forward to seeing it during the day. Again, great job on all the work you've done on it and being the original owner.
  • Wanted 6 bolt NT water pipe
    • chrisman287
