98 eclipse wont start after eprom install?????
hippy
322
Jan 18, 2004
chtown,
Its a 98 eclipse gsx with 6 bolt swap just got my 95 eprom socketed to teh dsm link chip and installed that computer and it wont start no fire to the plugs. But tried swapping out the eprom ecu and put my 98 gsx stock ecu back in and boom fired right up is there something i forgot to do???
Im pretty sure it is i sent my ecu to have it socketed and teh dsm link chip installed. Also tried switching plug wires around and still no difference. I t just seems to be getting no fire whats so ever with the 95 eprom in it?? Is there something i have to go into and switch with my laptop with the software??
Well, is the dsm Link set up for the 6 bolt swap or not? If it is then your problem is teh injector wires, to do teh swap in a 2g without the dsm link you have to swap the injector wires at the ecu, but the dsm link can manipulate the signals and swap it without any wiring, so if its set up for teh 6 bolt, then your injector firing would be all kinds of messed up. Also, was teh chip instaled the correct direction and all? Luck
