97 gst Overdrive not working
Ish
Jul 23, 2009
summit, New Jersey
I have a 97 eclipse GST. It's an automatic and the overdrive doesn't kick in. When I push the overdrive button, it doesn't engage and feels like it's in neutral. Someone told me it could be the relay or sensor. I would like to know if this is the problem.. If so, I need to know where the relay or sensor is located. Any help will be greatly appreciated.
You should probably go to a tranny specialist it could be a multitude of different things... and if you don't know where your relay is that should be more incentive to go LOL
I'd say your 4th gear clutches & plates are shagged.
ITP sell an upgraded set or you can buy a std set.
Box doesn't have to come out to replace them. Easy fix.
You may as well do a filter change & new fluid as well.
Cheers !
Did you get it fixed? I think it looks like I'm having the same problem.
I took my car into a body shop and left it there for two weeks to have work done it cause of an accident (got hit on driver side door). After picking up the car yesterday, I noticed the overdrive doesn’t work anymore. No matter if it’s on or off it doesn’t do anything. The light on the dash never worked since I switched to a new cluster last year. I always leave the overdrive on and never had a problem before taking it to the shop. When I test drove it and reached 60mph the rpm stays high, it feels like the overdrive is turned off and it doesn’t want to go into the next gear.
Thank you
Auto 97GST
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
