2G 97 Eclipse Spyder
DsmAngel
Nov 14, 2021
Indianapolis, Indiana
When I raise the convertible top the windows don’t go up with it as well, does anyone know the problem?
When the convertible top starts going down all the windows goes down automatically, when the top is engaged again to put the top back up the the windows automatically go down again and that's it. You put the windows up yourself after. That's done with the switches. My Spyder has never automatically rolled up the windows when putting the top back up.
The car doesn't know if the latch is locked or not, the windows will still go down, but you can easily damage the top motors leaving it latched.
If you have the soft top set to manual, all 4 windows will still lower together when hitting the switch.
Since there's so many electrical mods, maybe I'll start looking into the switch controls to see if they can be modded for raising them all at the same time.
@spyderdrifter .... I see you are from Wampum... Unless Trivia... Wompom
Small cylindrical beads traditionally made by some North American Indian peoples from shells, strung together and worn as decoration or used as money.
"Strings of wampum"
