97 Eclipse Spyder GST Talon body kit
Thedsmnewbie
Feb 18, 2013
Easley, South Carolina
how hard is it to put a 2g talon TSI front bumper and side skirts and possibly a rear bumper and taillights? can somebody explain what all i will need to do this?
Well the front is bolt on unless u are running a fmic. Then u will hav to cut out the bumper for the fmic. U will also need taolon headlights unless u want a gap. Sides transfer, just 2 side tape clean up. The rear will reqire the bumper up braketes transfered off the rear body panel. Which envolves drilling and welding . Tailights bolt on with a little rewireing.
U will also need taolon headlights unless u want a gap. QUOTE]
95-96 Eclipse headlights and 95-98 Talon headlights are the same. It's only the 97-99 Eclipse headlights that are different.
OP, search. This topic has been covered in depth before.
I have done the front bumper on my last talon. my headlights fit just fine and no gap. but fmic does require the crash pad in the bumper to be removed its fairly simple if you've never done it before. hope this helps.
