95 talon tsi awd motor swap to 97 eclipse spyder gst
97espder
Dec 19, 2009
New Richmond, Wisconsin
I puschased a 97 Eclipse spyder gst has a spun bearing i got a 95 talon tsi awd parts car it was rolled but drive train is all good is there anything i have to change when swapping out motors someone said they have different flywheels?
Has anyone made the spyder an awd swap from awd talon?
I ran into this when I put my 97 engine in a 95. 95's have a different CAS cam angle sensor) I ended up rewiring CAS and using the 97 ECU. Since you have both cars it should be pretty easy. Use the search on this site and the VFAQ site. They saved me a ton of issues during my engine swap.
what i did is swap the engine wire harness, went with dsmlink and a 6 bolt swap. the only thing i ran into was the ground wire at the fuel pump. i still have to check where it's broken so i just jumped the ground to yhe frame. other than that every thing else went just fine. just do your home work. get the swap done and running before you junk the tsi.
