2G 97 Eagle Talon TSi awd not getting fuel and wont start
Afue
Oct 12, 2018
sacramento, California
I have a 97 Eagle Talon TSi awd manual. I'm having problem with my car not starting. It will crank but won't start.
When the car is trying to start it will have a bogging sound like its not getting enough fuel. I swap out my fuel pump for enforce walbro 255 today and still the car wont start. Not sure what else to look for or to replace.
BTW, when I have the ignition on I don't here any fuel running or here my fuel pump on or anything. Do any of you know whats wrong?
Please help TIA.
I see nothing about you checking whether the injectors themselves were actually working. Fuel to the rail isnt enough. You need to check delivery.
what i did so far is, i replace the fuel pump, efi/mpi. I check all four spark.
is it possible to test with a injectors firing with a noid light if the car isn't starting up? Im watching some video on youtube and it seems like all of the video shows how to use that tool when the car is running.[/QUOTE]
will I be able to tell if my injectors are working if my car doesn't start while using a noid light? some video on youtube shows only using that tool when the car is on.
btw. anyone know of a good timing belt kit to get and water pump? oem spec
