klipschaudio
- 103
- 2
- Dec 27, 2007
tacoma,
Washington
I have a 99 eclipse, my engine blew so I got a 96 one, the only difference is the cas as far as im concerned, I checked the wiring diagram, and it shows 96 and 99 cas blue wire going to pin 88 on ecu, so I made my own little harness to go all the way to the other side of the 96 engine, car barely starts after 20 seconds and so i shut it down, something is wrong. I know the firing order is the same, they both had the 4123, so what is wrong?! The engine worked perfectly before I pulled it from this wrecked car and swapped it into mine, any suggestions appreciated. thanks
DSM!!! WHHYYY!!!!
Thanks for the clear advice gofer.
