'95 talon sputtering at idle.
caseyweed
Feb 6, 2006
Monroe, Washington
Here is the issue, my fiancée has a '95 eagle talon. I believe it is just the base model, there is no turbo any of that. It recently has had an intermittent problem when at idle it sputters and shakes pretty bad and then sometimes its fine. It's only at idle and not when driving. It's hard for me to diagnose because I have never actually been there when it's done it, I just hear about it. Has anyone had a similar issue? My best guess would be fuel or ignition related...Sorry I don't have more information but that's the best I can do unless it starts acting up with me in the car. Thanks in advance.
I own a 95 Eclipse Non turbo as well..had the same problem
first you wanna check you plugs and wires..easy fix if there is a fouled up plug, then move on to vaccum leaks, such as you intake manifold gasket could be worn out and leaking(which was my problem) that will definatly cause idle problems among other things(clogged fuel injectors, fuel filter, fuel pump, etc...)
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
