95 talon rough idle
Hardcore1
50
Aug 16, 2013
Arvada, Colorado
Working on a friends talon and the thing idle is screwed up it sound like it's camed but it's not. Checked all exhaust and boost for leaks and there is none. Check ignition coils for ohms and they read fine replaced plug wires no change. Plugs are new as well. Any ideas?
Sounds like a boost leak or the firing order is wrong to me, did you check the wires, plugs and see if all the injectors are spraying as they should?
