2G 95 gsx shell rebuild
Xavi
Oct 3, 2021
Connecticut
so im new to the platform and cars all together, got a 95 gsx shell as a project with a 6 bolt short block. but i cant find all the awd parts i need for the car. would 2g fwd parts bolt up no problem? if not what needs to be changed. thank you guys for any answers
Welcome to the deep end of the pool. Most people start their experience with cars with a working platform, and change one thing at a time building experience with each modification.
You sound like you're about to embark on a treasure hunt without knowing the list of treasures to look for, or any knowledge on how the treasure fits together.
It really depends what you're talking about. The valve cover is interchangeable, as are the seats. Rear axles are going to be tough to source from a FWD car, as is the AWD transmission and transfer case. Your question is too vague.
Yup way too vague. You have a 95 gsx shell and a 6bolt motor. I assume that's all you have?
yes thats all i have, sorry i didnt explain better. all the car has is a 6bolt and wheels.
You will need
Driveshaft
Front and rear axles
Transmission
Transfer case
Rear diff
Not sure if you have a flywheel but you’ll need a 6 bolt flywheel, clutch, correct starter plate and starter.
Does the shell have a gas tank? You’ll need an awd gas tank as well
That’s what I can think of off the top of my head
You will need
Driveshaft
Transmission
Transfer case
Rear diff
my question is, if i cant source the awd parts, could fwd parts bolt up? assuming i had all the peices for fwd. the shell does have a gas tank it has everything except transmission and drive train. Thank you a lot!
You will also need the correct awd exhaust as the fwd exhaust will not clear the t-case location. Also, you will need the proper fwd axles if you put a fwd transmission in for now. The axles are quite different between them.
