95 gst with 97 ECU
Evo2G
Jul 16, 2010
seaford, Delaware
I have a 95 gst with a 1g CAS(I did the roadraceegineering.com wiring diagram), the car wont start I took it to a shop and they said they think the ECU is bad because it has spark, fuel, and its in time.I found a 97 ECU and I wanna know if this ECU will work ? and if so is there anything special I have to do ?
I need to change the plugs wires to what ? Because I did this instead.
The spark coil signal is inverted. Looking at the coils, label each wire A,B,C,D. Change the spark plug wire locations: A is now C, B is now D, C is now A and D is now B. Another way to do this is to change the trigger wires to the coil, (3 wire triangle plug, next to the igniter). Switch the two blue wires. One is blue with red stripe, the other is blue with black stripe. The third wire that remains unchanged is black with white stripe.
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
    • ist dwa
