95 GS to 98 RS motor and tranny swap
rocker_topper
126
Jan 11, 2012
marianna, Florida
hey JW how hard it would be or if its possible to remove and replace the motor and tranny from my 98 RS with the motor and tranny from a 95 gs? both 5 speed manuals with 420A engines. My concern comes in with the obd1 and obd2 differences. Would i have to swap the ECU and all sensors between the motors or just a simple engine and tranny pull and replace? Thanks guys :)
Use the ecu and harness that is in the car that you are putting the engine in. There will be a few sensors that will have different plugs, it is as simple as swapping it from the old engine to the new one.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
