95 Engine in 98 body
MikeL18
43
Sep 27, 2008
St. Louis, Missouri
I'm wondering if this is a direct swap or if there will be modification needed.
I blew the motor in my '98 unfortunately and it's been sitting in the garage for a month and a half and I simply need to get it running asap, don't suggest a 6-bolt. The only available motor around is a '95.
I've heard the CAS is different. I do have the full 98 motor still, but the head bent a few valves. Not sure if I can just swap CAS's or if I should swap heads or what.
I do have DSMLink V3full if this helps.
Yes the CAS is different from 2ga to 2gb. I would just swap in a 1g CAS and make your own harness. :thumb:
