95 eclipse gs auto, weird trans problem
Gustar44
Sep 11, 2013
Cokato, Minnesota
i was driving and slowing down as i was entering a lower speed limit 30 .... i was doing roughly 40 when my car acted like someone quick turned the key off and back on... the transmission felt like it slammed hard, then instantly downshifted into 1st..... i pulled over right away.... i shut off and restarted my car... as i drove forward it did not shift out of 1st, and when i got to a gas station 1 mile away i found that my car would not move in reverse or neutral with the engine running... i later found that if i shift from reverse to neutral and wait 4-5 seconds it will slowly "let go" and the car will roll...... but in reverse the car seems like its stuck between two gears..... and a new problem showed the next morning, my battery was completely dead, so i charged it and again it was dead. .... ive swapped the tcm relay and checked ohm readings for the solenoid pack, and power at the tcm and everything seems ok...... please point me in what to check or where i should look next
