95 aftermarket cam gear question with CAS
jpmxrider489
2,415
152
Apr 4, 2010
pittsburgh, Pennsylvania
So I recently picked up a cheap set of gears for 50 bucks. I know I dont need it but it was a good deal. They are obx. I have a 95 talon and the CAS is under the intake gear. I know OEM gear has a ridge for the CAS. Can I somehow move that ridge to my new gear. I dont want to use a different CAS, I would rather use what I have. Is this possible? Anyone else do what im doing. Please share your experience.
There's actually a trigger plate bolted to the back of the stock intake cam gear. I purchased a set of fidanza adj cam gears and they had the bolt holes tapped in the back to move the plate over. So check for those holes in the back of the new intake cam gears. if they have them, then they should work.
Yeah, I've seen some people just run the adj exhaust cam and leave the intake stock. I think that's your only option aside from switching to the 6 bolt style cas
