420A 95 420a coolant leak
Robertlow88961995
Mar 28, 2017
Houston, Texas
I have a 95 talon with the 420a it has a coolant leak looks like back passenger side I motor I know my radiator cap is leaking that's the coolant leak on front but what about coming from the back? Could it be from the cap an just running down the block or a hose? Water pump is on front of the block but I don't know
Oh I forgot to add it never overheats and no matter how long I drive when I refill it every time I go somewhere it only takes a quart of water like a gallon will fill it up 4 times
If you know the radiator cap is leaking then why don't you replace it and see if the leak stops? They are really cheap. That seems like the best place to start to me.
heater hoses are on back of motor on fire wall sometimes they crack or rip just check make sure they are good or you can rent at a carquest or a parts store a coolant pressure tester kit n test for leaks good luck
