95 2nd Gen FWD ECU In 95 2nd Gen AWD?
These two ECU's are virtually identical. The only difference that I am aware of is that the FWD ECU contains a speed limiter - I believe it limits your speed to 130 mph. The AWD ECU does not contain a speed limiter. The reason for the limiter on the FWD is because the FWD's from the factory only had tires speed rated to 130mph.
EDIT: If you wish to remove this speed limiter, there are a couple of options - if you will be installing DSMLink, then DSMLink automatically removes this speed limiter. Another option, if you are electronics-savvy, is to perform the following modification to the ECU: http://www.dsm.org/how-tos/speedlimiter.htm. Hope this helps!
