1G '94 Talon Radiator Fan Installation Help
Papa C Gregz
Mar 30, 2014
The Soo, Michigan
Hey guys, when I purchased my Talon I noticed that I only have one radiator fan. I'm planning on autocrossing so I know it would help haha. My problem is how do I install one? I found one used but I don't know if I need some kind of relay or is it just a plug-n-play thing? Thanks!
Did you pull a fan from a 1g with the 2.0? It should just bolt to the radiator. 2 bolts on top and 1 on the bottom.
There should also be a plug for it already by the driver side headlight. I am, of course, assuming that the fan that isn't there is the a/c driver's side fan.
Your gonna have to wire them together as well, one of the plugs is for the ac fan only so unless you have them wired together it wouldn't do any good.
You could wire them together. Or you could just remove one of the A/C fuses (I forget which one) and then when you turn on the A/C button the fan will come on but not the A/C system.
Ok I see. Yes, the fan that I am missing is the A/C fan. Do the fans change between the 1.8 and the 2.0? I was contemplating purchasing a whole new radiator but alas, I do not have the money. Thanks guys for the help :)
I've never priced a OEM set up bit I did just buy a all aluminum radiator slim fans and aluminum shroud new off eBay for less than $200
I am fairly certain the 2.0 and 1.8 fans are different. The 2.0 non turbo and 2.0 turbo fans are the same, but the radiators are different. Turbo radiator is larger.
Ok, well I'll keep that in mind whenever I start shopping for a used fan haha. Thanks!
